ls7 stroker kits
Moderator
You probably wouldn't even want to use the stock sleeves for 1000hp anyways. At the very least, I'd use something like a MID sleeved block.
.030" over still doesn't make 440ci, more like 433ci, and you probably wouldn't want to go that far oversized with the stock sleeves if the goal is 1000hp.
and yes 440 is i believe 4.125x4.100?
