guys running 243s on 5.3 i need your advice!!!!
Old 10-24-2011, 11:55 PM
86 g-body's Avatar
Default guys running 243s on 5.3 i need your advice!!!!
Got a set of 243s with yellow springs.looking at putting them on my 5.3 after getting them milled down.so my ?s is HOW MUCH DID U MILL, WHAT SIZE HEADGASKETS DID U USE , WHAT LIFTERS DID U USE & WHAT SIZE PUSHRODS DID U USE?? I'm gona be useing a zo6 cam.. THANKS IN ADVANCE.....
Old 10-24-2011, 11:56 PM
01ssreda4's Avatar
243s come stock on some 5.3s. I would run a GM MLS head gasket and once assembled measure for pushrods last. For lifters, the GM LS7s are popular.
Old 10-25-2011, 12:00 AM
86 g-body's Avatar
OK so I use MLS standerd 5.3 bore gaskets??
Old 10-25-2011, 12:01 AM
01ssreda4's Avatar
Yep, should work fine.
Old 10-25-2011, 12:07 AM
86 g-body's Avatar
Thanks!!
Old 12-29-2011, 08:16 PM
Kory 88Iroc Lt1's Avatar
What year shortblock do you have? are the pistons flattops or dished? That will determine what you need to do.
Kory
