Fast intake Manifold?!?!
Should I install the fast fuel rails and injectors on the manifold before installing the intake manifold on motor? or install the rails and injectors after installing the manifold?
Internet Mechanic
If you can, do it before. but unless there is some sort of clearence issue with yours vs my FAST 90/90, then do what you can before. Also to mention make sure you put at least all the intake maniford bolts into the intake before attempting the install. Use some masking tape to prop them up.
IF this is your first FAST install, the coolant cross over tube in the front needs some messaging to clear for the neck. Also make sure the MAP is secured. I think from 92mm and on they included a tie down but just to mention.
