exact symptoms of bad oil pump o-ring?
Old 11-06-2011, 09:09 PM
rennocneb's Avatar
Default exact symptoms of bad oil pump o-ring?
So what are the exact symptoms of the bad oil pump o-ring trying to just be sure that its not the issue before tearing into a motor. The engine carries tons of cold idle and under power pressure. As the temp comes up the hot idle pressure drops to around 22-24psi on 20w-50. Note this is a built stroker with .0020 clearances. it still carries adequate oil pressure at anything above an idle just low at idle? ideas?
Old 11-07-2011, 09:54 AM
rennocneb's Avatar
no one?
Old 11-07-2011, 11:12 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
O-ring issues could be anything from pressure dropping under load, no pressure at all, low pressure all around, low pressure at idle. It depends on what is wrong with the o-ring (cut or pinched). If you have not already, I would first install a mechanical gauge to verify accurate readings.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 11-07-2011, 10:04 PM
rennocneb's Avatar
what is the easiest way to do this on an ls3?
Quick Reply: exact symptoms of bad oil pump o-ring?
