exact symptoms of bad oil pump o-ring?
So what are the exact symptoms of the bad oil pump o-ring trying to just be sure that its not the issue before tearing into a motor. The engine carries tons of cold idle and under power pressure. As the temp comes up the hot idle pressure drops to around 22-24psi on 20w-50. Note this is a built stroker with .0020 clearances. it still carries adequate oil pressure at anything above an idle just low at idle? ideas?
LS1Tech Premium Sponsor
O-ring issues could be anything from pressure dropping under load, no pressure at all, low pressure all around, low pressure at idle. It depends on what is wrong with the o-ring (cut or pinched). If you have not already, I would first install a mechanical gauge to verify accurate readings.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
