Western Members CA, AZ, NV, UT, CO, NM, HI
I need to replace my rear main seal and don't have much time to do it myself...
Old 11-16-2011, 02:08 PM
V68Sweep's Avatar
Default I need to replace my rear main seal and don't have much time to do it myself...
Just curious as to how much I'd be looking at to have one of my LS1Techers help me out here...and by help me out I mean do it for me. I simply don't have the time to do it right now and it's leaking pretty badly
I'm in Orange County. Thanks!
Old 11-16-2011, 03:18 PM
96blackta's Avatar
PM sent.
Old 11-16-2011, 04:11 PM
mannyman84's Avatar
M6 or a4
Old 11-16-2011, 04:13 PM
V68Sweep's Avatar
Originally Posted by 96blackta
PM sent.
Thanks!
Originally Posted by mannyman84
M6 or a4
Sorry, it's an M6 w/ a good 'ol rebuilt T56.
Old 11-16-2011, 06:45 PM
ZSS2148's Avatar
How have you verified that it is the rear main seal. The valley covers, valve cover and oil switch all have leaks that seem to be rear main. It was a low mile dry engine when I sold it to you.... I'm not saying you're wrong just trying to save you from unnecessary labor.
Old 11-16-2011, 10:08 PM
V68Sweep's Avatar
What's up Chris. No worries man I appreciate it! Will each of those parts you listed all leak in the same area? My valve covers/heads are completely clean and dry. I have not checked the valley cover. I've been seeing it leak oil for quite some time, and I was pretty sure it was the rear main seal until I got under the car. About a month ago I did an oil change and oil seemed to be leaking out of that tiny slit between the oil pan and bell housing.
Anyway to tell for sure before taking the transmission out?
Old 11-16-2011, 11:08 PM
gorr4's Avatar
humm I have the same prob & it's geting worce, i allredy got the new seal but Iv ben puting it off... it's a auto & has had the drip ever cince the deler worked on the trans, thats still not right... :/ but how to i check the outher spots? i just asumed it was the rear mane thers no oil on top that i can see & it's coming from inside the bellhosing. thanks in advance George #4
Old 11-17-2011, 10:53 AM
SCHP98ls1B4C's Avatar
I have a brand new rear main seal a gm one 30 bucks and it yours
Old 11-17-2011, 11:29 AM
V68Sweep's Avatar
Thanks man. I don't know if I'm going to replace it quite yet but if I do I'll hit you up!
Old 11-17-2011, 10:02 PM
a-low's Avatar
Also check the pvc line behind the intake. The y where the lines meet were rotted on mine
and all along i thought it was the rear main seal leaking.
Old 11-17-2011, 10:41 PM
lowerthanyou00's Avatar
+ 1 look for my cheap *** write up on how to fix it
Old 11-18-2011, 08:08 AM
gorr4's Avatar
link please
Old 11-18-2011, 11:20 AM
V68Sweep's Avatar
Good ideas guys, I appreciate you chimming in. Lowerthanyou00, do you have a link to it?
Old 11-18-2011, 11:42 AM
senor_camaro's Avatar
keep an eye on your oil levels until you change the seal, once you loose enough oil your oil pressure will drop due to lack of oil and you will ruin your bottom end cause there is no oil to lubricate the engine.
Old 11-18-2011, 10:01 PM
https://ls1tech.com/forums/general-m...l#post11076382
Here you go pm me id you got questions
Old 11-19-2011, 01:12 PM
KILLER-LS1's Avatar
hey fool, you dont have PCV lines
Quick Reply: I need to replace my rear main seal and don't have much time to do it myself...
