truck mainfold set, do i have to remover nh sway bar?
Was going to buy the mod Turbo hot side kit until I saw you can't use a sway bar. Is true with all truck manifold front mount set ups? Can I make my own, stand up the radiator and keep my sway bar or is it a lost cause with the truck mani's?
It is possible, but the most feasible way is to do the Vband mod to the end of the truck manifolds and cut them back a bit so they'll exit more horizontal than downwards. If you don't plan on doing any work to the truck manifolds, then yes, your Sway bar has to go.
