Throttle Body Recommendation
Old Nov 13, 2011 | 11:01 PM
Wicked69's Avatar
Default Throttle Body Recommendation
Here is a picture of the set up I am using. What throttle body would you recommend that would mount up to the elbow. How big? Here are the engine specs:
5.3 stock bottom end
arp rod bolts, head studs, LS9 gaskets, 160lb injectors, E85,LS HD timing Chain, Patriot Gold Dual Valve Springs, XER273 224/230 .581/.588 114 Factory PC and wiring harness, Hp tuners. Goal is around 850rwhp and running 15-19lbs of boost with twin Pt62/62's with .58 AR
Old Nov 14, 2011 | 06:38 AM
Fireball's Avatar
you don't need alot of throttle body for FI applications. I only ran a 90mm on mine at the 2000+ hp level.
Old Nov 14, 2011 | 06:42 AM
Wicked69's Avatar
So, could I just use a stock ls1 throttle body then for my goals? Does the stock TB bolt right up to the elbow or do you need an adapter?
Old Nov 14, 2011 | 07:56 AM
dschmittie1's Avatar
That Elbow doesn't look like it has a bolt pattern for a stock ls1 TB. Stock ls1 TB is 3 bolt all the other new and bigger TBs are 4 bolt.
If you are set up for it just get a 90mm 4 bolt TB.
Allthough I have gone 9.5@147 on a stock 78mm TB
Old Nov 14, 2011 | 09:32 AM
MIGHTYMOUSE's Avatar
any reason why you cant put the factory stuff back on? if not i guess you gotta pony up for whatever fits that thing.
Old Nov 14, 2011 | 09:40 AM
Wicked69's Avatar
Thanks. I got the intake and rails for only $250 so I dont mind spending some on a throttle body. Just wasn't sure if I needed to. I guess the fact that it is 4 bolt decides for me. Thanks.
Old Nov 14, 2011 | 08:36 PM
eviltwin_1987's Avatar
i dont see you getting 850whp out of a 5.3 at 19psi
Old Nov 14, 2011 | 09:29 PM
BadgeZ28's Avatar
I have had several aftermarket throttle bodies. I also had a ported stocker. Many of the stockers benefit from relieving the full throttle stop to allow the blade to open to parallel position. I had a BBK and now use a Trickflow. The Trickflow is the best so far. smooth transition, great response. A quality piece IMO.
Old Nov 15, 2011 | 10:39 PM
Wicked69's Avatar
It's not so much the hp as it is to break 6 sec in the 1/8. It should take around 15-19 psi to make that happen in my car.
FWIW-I found a UMI 90MM throttle body 4 bolt in new condition, used for mock up only for $200. That should be just about right for what I am doing and saving around a $130 over another aftermarket one I was interested in.
Old Nov 16, 2011 | 08:12 PM
Wicked69's Avatar
Just thought I would post that I found a 4 bolt UMI 90mm throttle body, Used but only for mock up and the occasional times they moved vehicles. $200. This should do the job.
