fuel sender with built in pump for 68 camaro
Old 11-22-2011, 11:20 PM
billyflantos's Avatar
Default fuel sender with built in pump for 68 camaro
im curious if they make a drop in fuel sender for a factory fuel tank for a 68 camaro that has a built in fuel pump and with low enough fuel preasure for a carb''d set-up...thanks billy
Old 11-23-2011, 08:09 AM
Docked Wage's Avatar
The tank is pretty shallow. 8" if I remember correctly. As a result I've not seen a combo pump/sender for the setup.
I just finished a 67 and ended up putting a sump on the factory tank then plumbing to a high volume pump.
Ken
Old 11-23-2011, 08:14 AM
Here's a short video. About 1/2 way you can see how the sump looks on the back of the car.
67 Camaro video
Old 11-23-2011, 08:41 AM
bczee's Avatar
Many will just add a TankINC intake pump setup and leave the factory sender in place.
I have also seen a few use the 4th Gen F-Body bucket setup, they had to shorten it, but one problem would be that the fuel sender is not of the same ohm range, I saw a thread that someone make a retro fit sending unit to replace the 4th Gen one with a sender of 0-90ohm to match up with the early cars (60's and 70's) Gauges.
Vetteworks makes at kit for the retainer rights to work with the 4th gen Sender bucket.
BC
Old 11-23-2011, 08:46 AM
sabastian458's Avatar
I just used a 90's Ranger external fuel pump, added Corvette filter with built in return, and it has been good for years. Supplying enough fuel for a heads/cam/intake/exhaust car, EST @ 450ish whp. Now I will say that when WOT with 1/3 tank or less it does lean out some in the 5000+ RPM range.
Old 11-23-2011, 08:47 AM
The real solution is to buy a stock steel tank and sump it.
Or, I saw that they now make a trick fuel tank already sumped with servicable intank filter and pump. But now we are talking about some serious $$$
Old 11-23-2011, 09:02 AM
bczee's Avatar
Or you can buy a Rick's or Valley tank with build in Pump setup and has the correct sender. but your talking $1200 or so.. both Summit and Jegs well list them. Stainless Steel tanks...
BC
Old 11-23-2011, 09:04 AM
tsnow678's Avatar
Is there a particular reason why you want it to be an in-tank pump? I used an external fuel pump from Autozone for like $25 and it worked flawlessly while I was carb'd and it was so quiet you had to listen really close to hear it pumping. I can try and find the number for you if interested. The pump comes with a prefilter and is regulated at 6-8psi for carb applications. I have an almost new sending unit for your tank out of my 69 Camaro if you are interested. Classic Muscle offers two different ones 1 has a lifetime warranty and the other is 90 days. I have the lifetime warranty one. PM me if you are interested. You are about 30 minutes from where I live.
Old 11-23-2011, 01:09 PM
Nasty N8's Avatar
We use tanks inc assembly but don't need much to feed a carb.
Old 11-23-2011, 07:09 PM
i seen they have in tank pump'd tanks for fi so i figured someone would make a in tank pump with low fuel preasure for a carb...
Quick Reply: fuel sender with built in pump for 68 camaro
