Parts needed for long block
Hi ! I am planning a ASE long block topped with a front feed whipple 2.9 supercharger into my 66 Beaumont (A-body) I am compiling a list of parts that I will need in a case where a long block has none of the supporting parts to do the swap. The whipple kit will come with fuel rails and injectors .
I will need 4l80 e with TCM ,flexplate
-engine ECU and custom harness
- all sensors , new or used to make it run
- front accessory assembly -no AC -for Vette or gen 5 camaro
- engine mounts , headers ,oil pan
-starter
-fuel pump (s)
Please chime in and add to my list so I have an idea what I would be missing by not having a complete engine take out from a wrecking yard. Do the sensors I need add up in cost quickly if they are all new? Thanks
-starter
-fuel pump (s)
You will also need the gas pedal if the planned throttle body is drive by wire. Depending on the year, you will also need the TAC module that relays the pedal input to the throttle body.
Other things that add up are fuel lines, baffled or sumpted gas tank and fuel pump to name a few
