Sponsored by: DashLynx
02 Camaro Morimoto Mini H1 Projectors
Old 11-25-2011, 09:32 PM
walter1234's Avatar
Default 02 Camaro Morimoto Mini H1 Projectors
Thought I share this with everyone, I just finished with the installation. The light pattern is even without the dangerous glare to the oncoming traffic. Worth every penny.
Attached Thumbnails 02 Camaro Morimoto Mini H1 Projectors-img00314-20111123-1903.jpg   02 Camaro Morimoto Mini H1 Projectors-img00317-20111125-1520.jpg   02 Camaro Morimoto Mini H1 Projectors-img00316-20111125-1520.jpg   02 Camaro Morimoto Mini H1 Projectors-img00318-20111125-1521.jpg
Old 11-25-2011, 09:48 PM
dabest09's Avatar
Awesome! I'm going to retro those here soon. What shrouds are those? And have you thought about painting anything around them black?
Old 11-25-2011, 09:57 PM
walter1234's Avatar
They are the mini gatling gun, I like the OEM look so I didn't paint it black.
Old 11-25-2011, 10:49 PM
dabest09's Avatar
What temp bulbs did you go with?
Old 11-25-2011, 11:02 PM
bad_408_vert's Avatar
What exactly did you have to do to install, focus/aim them properly after you took the headlight housing apart?
Any type of fabrication was required?
can we get more pics like the first one but on the road?
Old 11-26-2011, 12:52 AM
walter1234's Avatar
The bulbs are 4300K. Installation was relatively easy; the hardest part was leveling the projector on the housing. I had to mount the headlight assembly back on the car to adjust the level and perform alignment before gluing the lens cover back. Here is a link to the procedure I used for alignment.
http://www.coolbulbs.com/HID-VISUAL-...-PROCEDURE.pdf
I will take some pictures on the road in the next few days.
Old 11-26-2011, 01:01 AM
Did you have to trim/cut anything in the headlight housing and How does the projector actually securely sit in place?
Do you have hi & low beam in the same projector now since they are "bi-xeon"?
How well does the solenoid work to switch from high to lo beam?
Thanks for all the cool info!
Old 11-26-2011, 01:05 AM
walter1234's Avatar
Also if you want the projectors to stay on when the high beam is activated, some additional modifications are needed. Here is the wiring diagram from the Retrofit Source. A diode needs to be wired between the positive connection of the high beam to the positive connection of the low beam projector relay.
Old 11-26-2011, 01:11 AM
walter1234's Avatar
Yes, the projector secured in place with no additional cutting, but I added some epoxy to the backside for good measure. The bi-Xeon works well. I tested the solenoid before installation by connecting it to the battery. So far so good, the solenoids are still working.
Old 11-26-2011, 09:47 PM
TheSilverOne's Avatar
excellent work!
Old 11-26-2011, 10:14 PM
walter1234's Avatar
Per your request, here are some on the road pictures. The first and the third are low beam, and the second and fourth are high beam.
Attached Thumbnails 02 Camaro Morimoto Mini H1 Projectors-beam.jpg   02 Camaro Morimoto Mini H1 Projectors-beam2.jpg   02 Camaro Morimoto Mini H1 Projectors-beam3.jpg   02 Camaro Morimoto Mini H1 Projectors-beam4.jpg
Old 11-26-2011, 10:28 PM
You did a Clean install and the light output is great.
Thanks again for the info and the pics!
Old 11-26-2011, 11:46 PM
cep39's Avatar
Those look like a quality product with the added benefit of keeping a relatively stock look. Will any HID bulb fit into these, or are they only compatible with the bulbs sold by the same company?
Old 11-27-2011, 12:34 AM
dabest09's Avatar
Only accepts h1 bulbs
Old 11-27-2011, 02:20 AM
LT4vert's Avatar
For reference, they do also offer a morimoto kit using oem D2S bulbs as well.
Clean install and looks awesome. A gagillion times better than any possible aftermarket headlight in both form and function.
Old 11-27-2011, 03:11 AM
TruBloodTransAm's Avatar
Looks great!
Old 11-27-2011, 08:03 AM
Captain Double Post
BOBS99SS's Avatar
should have made a write up how you did it, i wanna do something like this but paint the lights all black,
Old 11-27-2011, 02:03 PM
Copy & Paste Moderator
VIP1's Avatar
Nice!
I'm adding this to the Lighting FAQ.
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
Unfortunately, the D2S version of this projector is an older design and the output is not as good. Which is a shame because D2S is a real OEM HID bulb (both versions of this projector are aftermarket however). The H1 version of the projector was designed with a H1 HID kit in mind. This H1 version is actually real HID projector and not a Halogen projector.
There are actually multiple versions of both the H1 & D2S version of this projector, but it seems that the current H1 version (4.1) still has better output than the current D2S version (2.0).
If you want to stick with an OEM HID D2S projector there are plenty of options but they all take a bit more work to install. A good option is the FX (and the FX-R replica). The RX330 and TL are also some popular options, but are a bit larger.
The output of the Morimoto Mini-H1 is actually close to the FX-R.
Old 11-28-2011, 08:38 PM
qwikz28's Avatar
Thanks for this. I've been wanting to do a retrofit for years now, but have been shying away from doing it myself and can't seem to get the funds to have them done for me. I might just suck it up and make this a winter project. I'll likely be pegging you with questions!
Edit: Cyber Monday deals led me to order projectors (finally). Looks like this is happening!
Old 11-29-2011, 08:30 AM
dabest09's Avatar
Me too lol. I spent so much money I didn't "need" to spend this week. Well I could say I needed projectors. Stock TA lights suck ***.
Quick Reply: 02 Camaro Morimoto Mini H1 Projectors
