LQ4 replacement pistons? What are options?
Old 11-26-2011, 08:42 PM
streetknight2's Avatar
Default LQ4 replacement pistons? What are options?
Picked up a LQ4 today as pretty much a buildable core. Haven't torn it down yet to see if it will need pistons, but if so what are my options? Anything out there to get the compression up? Was thinking of using L92 or LS3 heads, but not set in stone.
Old 11-26-2011, 08:58 PM
93Z2871805's Avatar
I don't think there would be anything wrong with the pistons in the motor unless it was hurt. But, if you're looking to bump the compression up, look for a set of 2004-up LQ9/LS2 flat top pistons with the floating pins.
Old 11-26-2011, 09:44 PM
lsxnation's Avatar
i just pick up a lq4 also , picked up a ls2 rotating assembly with ls2 flat tops.
Quick Reply: LQ4 replacement pistons? What are options?
