'00 z28 procharger build list, need opinions
I'm looking to go with a D1SC set up, i want to make 600-620 whp, I want this car to be my Daily Driver, and be able to rely on it. I know i need a cam, heads, pistons, rings, Rocker arms/lifters?I have a set up in mind, i'll link all the parts i have below, let me know what you think, and what I should change, also, i'll list the mods i currently have underneath the parts list i have. I want to thank you in advance for the help. Also, i'll be happy to answer any questions you have. Also I need to find a place to make a custom intercooler because I heard the front mount is a bitch to get to fit due to tubing issues
Parts List
-Tunnel Brace??
-ARP head studs
-PerfomaBuilt Level II Pro Race tranny(700 whp rated)
- QA1 stocker star rear shock, adjusty(2)
-QA1 coil over front shock, double adjusty(2)
-Pre 2004 Block ARP Head Studs
-Rear diff package(panhard bar, torque arm, LCA's, everything I need for rear)
-Auto Meter triple podJ
-Autometer electric Air/Fuel ratio PRO
-Autometer electric fuel pressure 0-100 PSI
-Autometer 7107 Mechanical vacuum/boost 30 In/20 psi
-Siemens 60lb injectors(8)
- Driveshaft safety loop
-MSD super conductor gen III
-Comp 26918-16 Beehive valve springs
-Aster tensioner(with new water pump)
-Subframe connectors
-Aeromotive 11142 stealth in-tank pump(340 LPH)
^^ for that pump, im not sure, haven't done much research, will that do? Or, can you reccomend one for me?
-Shock tower brace
- D1SC kit with Polished intake plenum, helical gear set(noise), balancer kit, pin kit, ATI race valve.
Current mods
-160 thermostat
-Pace Setter Long Tube Headers
-Texas Speed dual Cat Y-Pipe
-Magnaflow cat back single in dual out
-Ported Throttle Body
-SLP Smooth Bore Bellows
-SLP C.O.A
-Diablo Sport Predator programmer
Parts List
-Tunnel Brace??
-ARP head studs
-Shock tower brace
Current mods
-160 thermostat
-SLP C.O.A
80 lbs injectors, front mount intercooler, two fuel pumps, meth kit, Epp cam, tune, torque arm relocator, speed density so 2.5 bar, fuel rails, 8 rib, the kill switch. Intake manifold throttle body. Pro charger fmic fits easy.
I heard the front mount intercooler sucks *** to put in because you have to custom make piping to not hit the hood. And you have to bend an entire new inlet tube.
yeah, I forgot to post the rods >.< my bad, im goin 7.4" comp hardened push rods. What pistons and connecting rods should I run? I know im going clevite bearings, and already said ARP head studs. I'm not sure what to run for Pistons/C-Rods, as this is my first build, can anyone reccomend?
LS1Tech Sponsor
I agree, the 9.7 would be just fine. For boost you want a nice thick ringland on the piston. It is better to bring the compression down with a larger cylinder head cc. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
__________________
LS1Tech Sponsor
http://www.youtube.com/watch?v=xB7YF..._order&list=UL Bob
__________________
