Need help with harness
Almost complete with converting my harness into a stand alone. My question is when removing the 02 oxygen sensor which one do I remove? Front or rear of catalytic sensors.
Thanks guys... So here is question # 2 The harness that came with my engine had the 02 plugs cut off. The diagram below show my setup of 02 wiring setup, what style of plug do I require? and does each 02 sensor require a pink wire? I ask because the color wire I ended up with are
Light green Qty:2
Green w/white Qty:2
Tan Qty: 2
Pluple Qty:1
Plurple w white Qty:1
Light green Qty:2
Green w/white Qty:2
Tan Qty: 2
Pluple Qty:1
