wire mod for driver side frame rail and fuse panel?
Is there any way to hide or get rid of that awful mess on the drivers side frame rail under the hood on a 00 transam? I'm going all out on this paint job with graphics and air brushing outside and wrapping into the engine compartment and I don't want to have to astare at that garbage. Thanks
Just like the passenger side wire mod, you can drill a hole in the fender well near where the wires come through the fire wall. Pull you fuse blocks out of the plastic mount and remove the mount. Peel back the wire loom and electrical tape. Label the wires that run to the firewall, cut them. Run them thru the hole and back to the fuse blocks. Strip the wires and re-solder them together. Cover with liquid electrical tape thuroughly.
Might as well relocate the fuse blocks to the inside under the steering wheel!
I did it the long hard way, still working on getting it routed the way I want to keep all the right clearance and look.
you have to unplug the harness under the dash, and the connectors you did for the pass side wire mod.
pull the harness and cut a hole. it is a pain in the ***
Sounds like I'm in for some fun, is also like to eliminate the wires going across the core support as I am eliminating it and moving the radiator forward. I guess ill get the snips out and start cutting. Where would be a good place to go across the car? Also is anyone relocating the computer? What's involved with that
