5.3 turbo estimated rwhp
Starting a 5.3 turbo in 1996 Mustang Gt. Looking for high 9s with 3600lb race weight. Will this set up get me where i want to be! Here is the basic setup.
Stock 5.3 with head studs and rod bolts.
Comp Cams custom cam ( 226-228@50 585-588 lift with 115 lobe separation)
Stock ls1 intake and throttle body
80lb siemens Deka fuel injectors with Duel Walbro 255s
Front mount T serious Turbonetics 78/68 billet compressor wheel ball bearing .96AR running 15-20lbs boost
using truck manifolds custom hot side.
JGS 50mm wastegate Jgs 50mm blow off valve
Jakes Performance Stage 3 TH400 with trans break and will have two step aswell to help spool
Jakes Billet Street strip converter 3200 stall
8.8 rearend with 2.73s gears
27X11.5 tall Hoosier QTPS
Adjustable rear suspension so has somewhat of chance of hooking!
