Ls7 exhaust manifolds modified to fit narrow chassis
Old 12-10-2011, 05:12 PM
grobb284's Avatar
Default Ls7 exhaust manifolds modified to fit narrow chassis
Just recently took my parts to the welder and got my LS7 exhaust manifolds welded together. The large factory flange flange needed to be removed to fit the narrow chassis for the Avanti. The transition to the 2 1/2 diameter not only angles together in the horizontal in the picture, but the whole transition also angles inward toward the block, similar to a block hugger type header. The exit opening is then parallel to the ground. We used 308 SS sheet metal and tubing to form the transition, as the manifolds are stainless.
Went from this:
To this:
The following users liked this post:
Homer_Simpson (08-12-2023)
Old 12-10-2011, 11:34 PM
ChiScouter's Avatar
That looks like a great idea, any chance we can get a picture of them on the engine? Id like to see where they drop in relation to the engine mounts
Old 12-11-2011, 08:37 AM
Pop N Wood's Avatar
Nice work. Looks like they are going to come a long way down before they turn. You must have a big engine compartment.
Old 12-11-2011, 09:04 AM
grobb284's Avatar
Here is the driver's side when fitting them up:
Here is the passenger's side with only the tubular transition pieces tacked together:
Old 12-11-2011, 09:09 AM
grobb284's Avatar
No, not a large compartment at all, really quite narrow between the frame rails. However, the transition can be long, as we are bringing the exhaust underneath the frame rail there, beneath the rail "kickup." This is to bring the exhaust to the side pipes.
Sidepipes are shown in the photo below.
Old 12-11-2011, 10:31 AM
LS1 pwrd NOVA's Avatar
How much were the manifolds and how much would the fab work cost? I wonder if they could or would fit other cars?
Old 12-11-2011, 06:21 PM
72ssguy's Avatar
How wide are you rails at the manifolds?
Old 12-13-2011, 07:29 PM
grobb284's Avatar
I'm thinking it's 24.5" wide between the front rails.
Having said that, if you wish, I can go out and measure in a few days. (stored in a remote location).
Manifolds were on an online auction, generally in the $150/pair range.
I did the fab work, is probably substantial to TIG weld. A friend did the TIG welding.
Old 12-21-2011, 04:42 PM
jakeb's Avatar
Do you have some measurements of these? mostly how long they are from the top of the bottom of the flange? How much do they kick out? looks like they are pretty tight.
Old 12-21-2011, 05:22 PM
72ssguy's Avatar
Here are some measurements that I recieved from user wadd:
rough measurements:
from the bottom of the mounting flange to the collector - 7"
Then, using the mounting flange as a reference plane (i.e laying it flat on a table) distance from
plane to inside collector flange 1/2"
plane to outside collector flange 5 1/2"
He responded under a post I made regarding these manifolds.
Old 12-22-2011, 05:58 AM
fieroguru's Avatar
I did pretty much the same to extra room on my transverse installation as well:
Quick Reply: Ls7 exhaust manifolds modified to fit narrow chassis
