Lsx Sound question?
Lsx Sound question?
Anyone notice with their lsx intake they have more sound from it? I have a hollow type sound that I hear inside the intake, anyone else notice something like this? Other than that it's fine. Thanks
Originally Posted by EVIL
i heard someone earlier say that since it sits right on the valley pan, it might transmit more noise than normal.
I intalled my LSX about 2 weeks ago. The only differn't noise I hear is that the intake noise has a deeper growl to it (I like it). Mine does not sit on the valley floor but about 1/4" - 3/8" above (they give you round headed internal wrenching bolts and these help with the clearance). Also, I have noticed the car pulls constantly hard all the way up to red line from about 3000 rpm. Before, I could feel the pull going away as the rpms went up (my car is a 2001 and I had the LS6 manifold). The only problem I had with the installatoin was the Throttle Body. I had to machine the cable pulley end down some so it would go full open. I also made a mount bracket for the MAP sensor that connects to the rear of the manifold (the bracket actually clips onto the back of the manifold and then the MAP sensor clips to it, it works pretty good). I also used the factoy manifold bolts to mount the LSX down. The factory bolts are alot easier to install then the allen wrech bolts that come with the manifold (they are exactly the same size/length so it bolted down real nice).
My valve train noise was amplified about 10 fold by the LSX. I figure it's because it touches the valley cover, and the LSX is just a big echo chamber. And the hissing noise from the AIR pump when it first starts seems louder too. My neighbor asked if I had put the S/C on it already! lol
