PE table question....boosted applications
This is on a 98ls1 running 1bar sd tune. I know that upgrading to a 2.5/3 bar os offers a boost enrichment table. Most things ive read say that the PE table should be one number across the board. i have tuned my VE table up to about 3-3500 rpms. Im about ready to start getting into boost (4-6lbs). I log an a/f error histogram at a min of 50 hits. Now that makes it hard to log any upper rpms (especially a boosted 2 or 3 gear pull.) Shouldnt I set my PE numbers to start going up as boost kicks in???? as opposed to just one number across the board? Just thinking Im missing something here. Probably should just go ahead and upgrade the O/S 1st huh? I just hate guessing. Thanks!
Brandon
Brandon
The BE table is not a must have. Your PE will not be the same across the board with a boosted setup. Set it to your desired NA a/f and then once boost comes in set it to your desired a/f example 12.7 upto 3200 rpm then 11.5 or what ever you choose to run. It is hard to get good high rpm data on the street without losing traction or doing 150 mph! Time to rent some dyno time.
1 Post
At low boost levels, and on blower cars, you can usually get away with using the PE table - the problem is that the PE table is laid out by RPM, and boost is not always a direct correlation to RPM (more so on a turbo car)... if you do a pull in second gear, and then do one in fourth, you will find that the boost/RPM correlation will not be the same (on the street, track, or a load dyno)... When you go to a 2 Bar OS, you are setting your desired AFR based on MAP readings instead of RPM readings - makes for much better control, especially when you get into higher boost levels...
If you are running only 4 to 6 pounds, you will be fine doing it as stated above...
