Tail lights
Tail lights
I'm experiencing a problem with the passenger side tail lights being brighter than the drivers side. I've replaced all bulbs in both tail lights.
Thanks for the help.
LS1Tech Administrator
Received 1,799 Likes
Is this on a Trans Am/Firebird? I'm assuming so, because I've never seen this issue on a Camaro.
If you are using the same bulb type/number in all sockets, then the issue is likely due to a lens problem. Sometimes they leak moisture, which darkens the lens, and over time will deteriorate the internal reflector making them even more dim.
