Which stock car LS2 throttle body?
Old 12-21-2011, 11:56 AM
samckitt's Avatar
Default Which stock car LS2 throttle body?
I have about come to the conclusion that I will need an LS2 throttle body to work with the GMMP LS2 controller kit I have, instead of the LS3 throttle body I put on the motor. I have LS3 heads & intake & the Vette accessories & injector covers. Is there a particular throttle body I should stay away from, or one in particular I should look for? I need a drive by wire one & preferably not one that will choke it down, bigger the better right?
Thanks
Old 12-21-2011, 12:55 PM
SweetS10V8's Avatar
You need to make sure you get the 90mm DBW with the silver blade, not the gold blade. Becuase there was never and LS2 with the gold blade.
Old 12-21-2011, 02:14 PM
samckitt's Avatar
I bought an LS3 throttle body (with gold blade) then found out it won't work with the LS2 tune. So what do I find the 90mm one from?
Old 12-21-2011, 04:43 PM
SweetS10V8's Avatar
The picture in the add??? Silver blade LS2/LS3 throttle bodies were basically from 2005-2008 or 2009ish.
Sell your gold blade one, it isnt reverse compatible.
Quick Reply: Which stock car LS2 throttle body?
