F/S Fast 90mm Intake & Holley 90mm TB. and a few more things
Category: Engine - Intake/Fuel
Price: $800
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): KY
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
The intake has some match port work done to the runners and intake to TB to give a smooth flow of air. And also been drilled a tapped for fogger nozzles, but has threaded plugs installed if not using nitrous. The 90mm Holley TB comes with all sensors, and it has a few small nicks on the top of the TB ,see in pics. This is a nice setup , It came off my LS2 418cid. and the engine run a 6.09 @ 113mph. so it does work, lol... I will throw in the rear steam block offs & front crossover tube. What i don't have is the valley cover bolts that clearance the intake. All Stainless Steel Allen bolts included (not valley bolts).You can see pics in my sig. on the engine with the parts install.
$800.00 shipped SOLD
Also have a used 4L80 Flywheel with spacer & bolts $60.00 shipped
Used LS6 valley cover $45.00 shipped
Used Set of 8 - 42lbs. green top injectors $200.00 shipped
sold
pay pal preferred lewis_randy@bellsouth.net
