Are You Running Hella 60mm Projectors?
If you have been running the Hella 60mm projectors AND a 50 watt HID kit, for more than 1 year, have you noticed decreased light output? The reason I ask is because a lot of projectors cannot handle 50 watt HID's. The reflector surface inside the bowls can melt and cause a decrease in output over time (Typically from 1 year on). Just curious what others experience has been with this, and if anyone can verify that their bowls are still good? Especially those running them for 1, 2, 3+ years. Please list the capsule manufacturer as well if you don't mind (DDM, VVME, Morimoto, etc).
Thanks.
Thanks.
