finally finished ls1 383 build!
Old 12-23-2011, 11:13 AM
kpadlina's Avatar
Default finally finished ls1 383 build!
i've been building a ls1 383 stroker with forged internals for a couple weeks now. I put manley crank and rods in it and race tec pistons lowering compression to 8.7:1
the anticipation is over and the build is finally done!
http://img.photobucket.com/albums/v6...s/IMG_0354.jpg
http://img.photobucket.com/albums/v6...s/IMG_0367.jpg
http://img.photobucket.com/albums/v6...s/IMG_0376.jpg
http://img.photobucket.com/albums/v6...s/IMG_0390.jpg
http://img.photobucket.com/albums/v6...s/IMG_0393.jpg
Old 12-23-2011, 11:41 AM
djfury05's Avatar
why such low compression? how much boost do you plan on running?
Old 12-23-2011, 12:02 PM
kpadlina's Avatar
I wanna be able to run around 15-18. gotta save up for another blower though
Old 12-23-2011, 12:04 PM
kpadlina's Avatar
and I want to be able to still run pump gas
Old 12-24-2011, 04:08 AM
djfury05's Avatar
you could of done that on 9.5:1 even.. going to be a dog when not in boost
Old 12-24-2011, 05:42 AM
bww3588's Avatar
that depends on how much overlap the cam has...or doesnt have in a blower cam case. a negative overlap will drive the dynamic CR up....
remember not all scenarios are determined by static compression alone.
Quick Reply: finally finished ls1 383 build!
