2002 Camaro B4C 1 of 18 Red RARE
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $15800
Mileage: 25900
Private or Dealer Listing: Private Listing
Location (State): NE
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
Andrew
402-560-4695
Dyno Video
Pictures
Heres a general list of the mods done to this car. Im sure I will miss some things.
Engine
Factory LS1 shortblock, Patriot Performance CNC'd heads, hardened pushrods, Roller Rockers, Aftermarket Cam & Lifters (guessing the GM hot cam), FAST 90MM intake and Throttle Body, MTI Performance Induction Air Lid, MSD Plug Wires, TR5 copper plugs, upgraded timing chain set, ls2 valley cover, ARP pro series rod bolts, and an SLP MAF sensor.
Transmission
Stock T56 6 speed, (BBS) Hurst Shifter (factory installed) with a Short Stick Installed, Aftermarket clutch (brand unknown), stock aluminum driveshaft with upgraded U-joints
Suspension
All Spohn parts - Strut Tower Brace, Sway bar end links, Fully Adjustable Torque Arm with tunnel mounting setup and 3 drive shaft loops, double adjustable lower rear control arms LCA relocation brackets, double adjustable rear panhard bar. 3.73 rear gears with a detroit locking differential and an aftermarket diff cover with the diff carrier cap supports. Slotted and Drilled rotors on all 4 corners, riding on stock B4C Springs and shocks. Hurst Line Lock.
Exhaust
Bassani Mid Length Ceramic Coated Headers, Matching 2.5" Stainless steel Catted Y-pipe, Stainless I-pipe to a Polished Magnaflow Muffler, mated to a Factory SLP Center Mount Exhaust Valence/Tip System. (Car has a nice growl at idle and is pretty quiet throughout the RPM range so definitly nothing much louder than stock. The Centermount exhaust system was only available on SS camaros, and this setup was Factory Dealer installed before this car was sold along with the SLP SS wheels/tires by Sam Pierce Chevrolet in Indiana.
Appearance
SLP Centermount Exhaust System (factory), SLP SS Bowtie Front Grille, OEM GM SLP SS Ram Air Hood, Fully Base/Cleared Engine Bay, SLP SS Chrome "Fat 5-spoke" 17" wheels and Tires (Tires are all 80%) (factory installed)
The only flaw to this whole car is the Title is marked not actual mileage. I bought the car due the the previous owners going through a divorce. The wife ended up with the car and I picked it up from her. It was her husbands car and in the process of signing the title over he marked the mileage NOT ACTUAL before sending it to me. I tried numerous times to get it fixed through the courthouse but they told me there was nothing they could do. The carfax/autocheck clearly shows actual mileage. This is a clean title car in amazing condition. I have more pics on my other computer I can upload. This car will not dissapoint. The lady I purchased this car from told me here husband paid $21,500 for it a few years and about 2500 miles ago. Its worth every penny im asking for it.
Had the car on the rollers yesterday. ended up putting down 400. the cam is very small and not much bigger than stock. A larger profile would definitly help the numbers out as the intake/heads/exhaust are setup for it.
Its explained in the description of my ebay auction. It is actual mileage but due to what the seller did when he signed the title over, there was no way for us to get it corrected. the carfax/experian autocheck will clearly show its actual. I have a copy if your interested in seeing one or both.
Back to the top. Less than 3 days left on the auction. We have posted any more findings on the car on the listing as well as the reserve price. Thanks
I remember this car from when it was for sale in here in Indiana! I talked to the guy who owned it a few times over the phone. I want to say the cam was 218/220 but I honestly don't remember. I was very close to buying it when I bought my z28 locally instead. Good luck with the sale, it is a very nice car.
Bumping this back up. Fired it up this weekend and let it run for awhile. Forgot how MINT this car is. still smells new inside. This thing is in amazing condition.
I remember this car I totally believe you on the title..... God thats the only part that sucks.... He showed her. He said he was going to do that.... Safe car to buy for sure. Mark it exempt it's old enough to do that...
Its definltly a show quality car. Still smells new inside. Spring is right around the corner so I'm sure it wont be long before it's sold. I've listed it on autotrader and have started getting calls.
