200 shot good idea for first shot
Talked to the guys over at nitrous outlet. Decided Im going to buy there 98=02 complete plate kit. I want to put the kit on it and go for a 200 shot. This is my first time using spray so I was just curious what you guys think. The spark plugs will be 2 deg colder and I will order the LC1 Wideband through Nitrous Outlet as well. So all that leaves me is to but a switch panel to wire everything too correct?
Is there anything else I need? Would my fuel setup be fine with just a 255 pump and 42' injectors?
Thanks guys
Chris
Thanks guys
Chris
I would not do 200 shot at first at all. Start off at 75-100 make sure your A/F is good and go up from there checking plugs. You put money into the car just make sure its all good before you step up to 200 shot.
