What budget block for a big inch/low boost build
Old 12-29-2011, 07:15 PM
stevo8's Avatar
Default What budget block for a big inch/low boost build
Looking to start building a bottom end, but want to get the block on the cheap if possible. The motor will be run on 91oct and meth with most likely a tvs2300 on it. It will be a street car in the mid to high 3000lbs range. 6.0L truck block be the easiest to source?
Old 12-29-2011, 07:27 PM
RARON455's Avatar
You can pick up one of the 6.0 blocks pretty cheap, and that can easily get you in the 400+ cubic inch range.
Old 12-29-2011, 10:06 PM
Z28SteveA4's Avatar
6.0 block is the way to go man. They are everywhere these days and are pretty cheap. They can be bore out and can hold the power. just for ***** and giggles i just got the new summit mag today and they have there own 6.0 block they sell now thats ready to go. might want to check it out, just an fyi.
Old 12-29-2011, 10:10 PM
stevo8's Avatar
Awesome thanks. Anyone have a link to a list of what vehicles/years oem cars came with 6.0's? Also, with the tvs2300, and e85, could the aluminum block see its limits? Or would I need a much bigger blower to really push it? I would like the weight savings but don't want to see block issues.
Old 12-30-2011, 12:01 AM
billetproof97''s Avatar
You can find the 6.0 in alot of trucks. If your wanting a lq9 those are in the suburbans iirc. Lq4's are cheap for sure. Alum (sp) is softer not sure what kind of abuse it can take. Im sure a guru can chime in.
Old 12-30-2011, 01:40 AM
82cetuner's Avatar
LQ4 (Low Compression)
Chevrolet Express/GMC Savana
Chevrolet Silverado 2500 Pickup, 3500 Pickup, Crew Cab, and Chassis Cab/GMC Sierra 2500 HD Pickup and Crew Cab, C3, Denali, and 3500 Pickup and Chassis Cab, 1500HD Crew Cab
Chevrolet Suburban/GMC Yukon XL Denali
Hummer H2 SUT
GMC Yukon Denali
LQ9 6.0 (10.1 compression
2002–2006 Cadillac Escalade
2002–2006 Cadillac Escalade EXT
2003–2006 Cadillac Escalade ESV
2003–2007 Chevrolet Silverado SS
2004–2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only [Badging on truck](B4V)
2006–2007 Classic Chevrolet Silverado and GMC Sierra VortecMAX Option
there are newer 6.0 blocks but they are 4th gen and have VVt and things like that on them the L76 is one if them
Old 12-30-2011, 06:50 AM
SOMbitch's Avatar
LQ4/9 blocks are the exact same just the internals are different. Since you are building from scratch either will work for you. A bare one should go in the $2-300 range.
