Stock A/C system from a 98 camaro into a 69 is it possible??
hello, I have a complete A/C system from a 98 Camaro, just bought te kuiwk brackets and would like to know if its possible to install it on a 69 camaro?? anybody has done this before??
thanks!
thanks!
The kwik a/c bracket is designed for use with a sanden 508, which I am pretty sure is different than the 98 ac compressor.
If you have the whole a/c system: evaporator, compressor, condensor, etc. I guess technically it could work, but you will have to see how well the evaporator fits under the dash and find a way to mount it. You will also have to figure our how to operate it. Did you get the ac/heater controls also?
