Which rings for my LQ9 build?
Old 01-10-2012, 04:30 PM
streetknight2's Avatar
Default Which rings for my LQ9 build?
It's pretty much a stock rebuild, LS3 heads, Patrick G cam, and running a carb. Going in a fox mustang with a TH350. I may spray 150 on it depending on how well it runs on motor. I didn't know if I should get the stock replacement low tension rings or a plasma moly or what.
Thanks for any help.
Old 01-10-2012, 04:36 PM
JPH
JPH's Avatar
A set of Mahle or Hastings std. tension oil should work fine for you. If N20 is in the future for sure, use a "Hellfire" Sealed Power ring.
Quick Reply: Which rings for my LQ9 build?
