LQ4 as my base where should i go from here?
Old 01-15-2012, 02:42 PM
1999Hugger's Avatar
Default LQ4 as my base where should i go from here?
Im having a probelm on deciding on what i want to do for my build. The motor will be going in a 1999 M6 Camaro, it has full suspension already, BMR K memeber, upper and lower tubular control arms, chasis mount torque arm, LCAs, Panhard bar, QA1s all 4 corners. My budget is going to be around 6 thousand, maybe a little more. I already have someone who is going to build the tranny and rearend. I have a 9" Housing that i still need axles, center section and drive shaft for. I also have an ls7 clutch in it right now and i dont know if its going to hold the power once its all done. So could you PLEASE help me out people.
Old 01-15-2012, 02:44 PM
1999Hugger's Avatar
Oh and one more thing, it wont be my daily driver once its done.
Old 01-15-2012, 03:11 PM
Turd Gen Guy
1nasty86's Avatar
Trickflow 225's or afr 230's, custom camshaft, better clutch, fast 102... Or front mount 76mm, truck manifolds, L92 heads, ls3 intake.
Old 01-15-2012, 03:32 PM
red fury's Avatar
With your budget in mind, maybe a keep it at 370ci so you could reuse the stock crank and use some N20. Then see what you have over to spend on some LS3 style heads and intake. That would get you around 470rwhp n/a and with a 150shot put you well over 600rwhp ... just a thought.
Old 01-15-2012, 04:22 PM
98SSClone's Avatar
Hmm... I say junk the car and sell me your suspension stuff
On a serious note. The setup in my sig has been proven a few times to run low-11s consistently. I don't have any times yet personally, but I've seen pretty much the exact same combo (only difference was the other car had a FAST 92/92 where mine is a 102/102) run a 11.08 in the 1320. Add a 100 shot and you have a mid 10 second car.
Old 01-15-2012, 09:16 PM
1999Hugger's Avatar
Ya guys I've been looking on here under the classified sections for some heads and a 102/102 setup. The biggest deal is deciding to go with a forged 370 or a 408.
Old 01-15-2012, 11:59 PM
wildcamaro's Avatar
i would bore it 30 over and throw 4 inch crank for a 408 and then run an l92 top end cammed and you will have one bad boy camaro
Old 01-17-2012, 03:14 PM
Kevin@Vengeance's Avatar
You've got plenty of options! Just gotta figure out which route you wanna start with. Are you thinking a N/A set up or maybe going with a power adder? Either way we can help with any questions or putting together a power package today! Here's an attachment to our online store.
https://www.vengeancerd.com/ecart/
