How would you fix this FAST90 intake?
Old 01-15-2012, 06:52 PM
03EBZ06's Avatar
Default How would you fix this FAST90 intake?
What are the FAST intakes made of? Are they fiberglass or some composite stuff? I'm wondering if I can just fiberglass this problem over, maybe even make it stronger. Not sure if the material will bond w/glass though.
Ideas? If not, who has a lower or a whole FAST 90mm for sale?
Old 01-15-2012, 07:42 PM
JRENIGAR's Avatar
Id use a $2 bottle of locktite superglue. It would break in a different place before the glue would let go IMO...
Old 01-15-2012, 07:47 PM
bronx_peanut's Avatar
Try some 2 part epoxy Jb weld etc.
Old 01-15-2012, 07:51 PM
BrntWS6's Avatar
Damn, did you drop it? I've seen some lowers on E-bay but not many.
Old 01-15-2012, 07:59 PM
82cetuner's Avatar
JB weld would be my best guess but JB weld it from the outside so it cant get sucked into the engine if it comes off.
Old 01-15-2012, 08:36 PM
sepsis's Avatar
....and these things cost $900 for some shitty injection molded plastic. Great product FAST/Wilson w/e.
The more stuff like this I see, the pissier I get about overpriced parts.
That sucks man, hope you can fix it.
Old 01-15-2012, 08:44 PM
Fafonfoe's Avatar
Hobby glue for RC planes. Very Very strong and will fill in the crack smooth. You might have to lightly sand. It will be perfect. Holds Very well.
Old 01-15-2012, 08:48 PM
sjsingle1's Avatar
find out what kind of plastic fast uses and get the "PROPER" glue......any glue WILL not work on ANY plastic......but it is fixable
Old 01-15-2012, 08:56 PM
Macs98Z's Avatar
This. You MUST know what the composite is made of before you start using just any glue. Some glues will break down certain types of plastic they were not made to work with. An epoxy (like JB weld) you probably will be ok with, but I would still check just in case.
Old 01-15-2012, 09:39 PM
03EBZ06's Avatar
At this point, anyones guess. I do remember jacking the front of the engine to get headers in a while back and manage to crunch an oil sender. Idle was hanging lately, so I decided to track the problem thinking vacuum leak and found this.
It was never dropped that I remember. Personally, I wonder if the cold nitrous charge did it. It has the trademark look of a backfire, but it never has.
Old 01-17-2012, 01:19 AM
NemeSS's Avatar
Some kind of adhesive, epoxy or jb weld. Ive used liquid nails, yea liquid nails to repair a ls1 intake manifold. Had some cracks from being crushed. I laid beads in the cracks,set them in and let manifold sit for bout 3 days,then sanded and painted it. Worked great.
Also used same stuff to repair cracks in my ftp lid, dam that thing has been brittle since new
Old 01-17-2012, 06:41 AM
tillery's Avatar
Was thinking a stop drill to keep the crack from continuing and then repair crack.
Old 01-17-2012, 08:31 AM
Detroitmuscle's Avatar
I have repaired one before successfully and unsuccessfully. I tried JB weld and that lasted all of maybe a day the repair that lasted a few seasons before I tore it apart again was a 2 stage epoxy that we also used in conjunction with some aluminum that we riveted to the intake. I also tried to have it plastic welded but they said it wasn't possible because the intake is composed of several different plastics. My opinion would be to contact FAST themselves they recommend a product to use on their intakes that should work the best.
Old 01-17-2012, 10:32 PM
sjsingle1's Avatar
this !!!!!!!!!!
Old 01-17-2012, 11:02 PM
jarheadtex's Avatar
I used 3m (i think) plastic weld on my ls6....works perfectly.
Old 01-17-2012, 11:11 PM
01ssreda4's Avatar
Soldering gun, gently melt it back together on both sides. Does way better then glue that prolly won't stick anyway
Old 01-18-2012, 05:01 PM
chikn305's Avatar
My fast has almost the exact crack. I tried jb weld it didn't last the drive home then loctite plastic weld it lasted for a month. Then I fiberglassed it. It lasted about 1000 miles. I'm still trying to figure out a permanent fix.
Old 01-18-2012, 08:05 PM
01ssreda4's Avatar
Read above again.....I do it to four wheeler fenders all the time.
Old 01-18-2012, 08:19 PM
2xLS1's Avatar
I've seen quite a few of them crack in the same spot.
Old 01-18-2012, 08:22 PM
Monzsta's Avatar
You have to make sure you get all the oil off the thing. I'd clean/prep it with the green cans of brake clean. That **** DOES melt plastic... be careful. Then I'd drill through holes along the crack and use a 2-part general epoxy, and make damn sure the interior was bonded through from interior to exterior. Back the interior side with speed tape and let the epoxy set with the manifold upside down. The stuff seems to want to flow forever 'till it sets. Don't forget to take the tape off after.
Quick Reply: How would you fix this FAST90 intake?
