P0121 tps code questions
Old 01-27-2012, 12:46 PM
stewdy1's Avatar
Default P0121 tps code questions
Ok I have a ls swapped mustang here couple details
346
11.5:1 cr
M6
Fast 102/nw 102
Pat g tuned
All new sensors on intake even tps and tb is new as well
Well cars been running great except for a intermittent hanging idle at 1500 rpm until I get down to 20 mph then it drops to 900
And this code keeps comin up for the tps sensor
Any thing I could look at or do to fix it is greatly appreciated
Old 02-01-2012, 05:49 AM
zanthor991's Avatar
Bump for curiousity....
I'm having similar issues. Don't remember the code but TPS Low Voltage. 3.84v at 100% throttle. I think it had 4.8v ref. New sensor.
Old 03-05-2012, 01:38 PM
Chicken Coupe's Avatar
I am having the same issue with mine. I wish someone would answer this. My tuner said is not in the tune. I say it is. This code will set if your MAF reading at a certain rpm VS throttle angle is not within the set parameters it will set this code for TPS performance. I tested my TPS while it was hanging at 1500 rpm and it was at .68 volts. Thats well within specs. If I unplug the TPS it will idle right down. I also performed a sweep test and tested fine with no glichtes. It is a new TPS and throttle body. It has a card type LS2 MAF 98mm big, with PP 101mm tb and a PP 96 mm Intake. I would love to have an answer.
Old 05-07-2012, 05:34 PM
ross.cottrill's Avatar
im in for this aswell..i ahve a heads,cam,fast 90/90 ls1...new tps sensor aswell and keep getting this damn code...its driving me nuts!!
Old 05-07-2012, 07:49 PM
BLK02WS6's Avatar
The TPS vs RPM test (lower) needs to be modified - For this diagnostic test the PCM will monitor the actual TPS position and engine RPM then referring to this table will expect the TPS to be above/equal to these values for a given RPM. For cammed cars that idle above stock RPMs the lower thresholds may need to be lowered to stop a TPS fault code being set.
Old 05-07-2012, 08:07 PM
5.3blazer's Avatar
i kept getting that code to, put on new tps and code went away and has not came back since
Quick Reply: P0121 tps code questions
