SOLD**LMR LSX 454 NBM Camaro FS**(Pics/Vids)SOLD
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $22500
Mileage: 48000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
http://www.youtube.com/watch?v=66OaRKMG7FI
http://www.youtube.com/watch?v=fTQ5Ta75wiI
-F.A.S.T 90/90 Intake and TB
-ET Performence 255heads
-Comp Cam
-ASP Pulley
-454" LSX Shortblock. .
-Callies 4340 4.125" crankshaft,
-Callies 6.125" H beam rods w/
-ARP 2000 7/16" bolts,
-Wiseco 4.187" custom forged nitrouspistons w/ lateral gas ports, Childs & Albert FirePower rings .043"
.-043" 3mm (for reduced friction & high heat applications), Clevite
-2199 H main brgs, Clevite CB663 H rod brgs, Dura Bond CH-23
-cam brgs, ARP main studs 6,699.00T
-Timing chain Roll master double roller timing set w/ torington bearing & nitrided gears.
115.00T
-LS1 Oil Pump Melling 10295 coated high pressure oil pump/ ported 129.00T
-LS2 block LS2 block conversion kit: LS2 timing cover w/ cam sensor, LS2
valley cover & cam/ knock sensor extension harness.
255.00T
-Moroso LSX oil pan Moroso LSX sheetmetal aluminum oil pan w/ custom pickup tube 595.00T
-gaskets LSX oil pan gasket
-Underdrive Pulley
-Kooks 1 7/8 headers/ Kooks y-pipe
-Borla Cat-back
-Mcleod twin disc clutch/ Alum flywheel
-Fully built T56 Transmission with Viper internals
-Pro 5.0 shirter
-BMR Chrome Moly Tubular Rear Control Arms
-BMR Adjustable Panhard Rod
-BMR Strut Tower Chassis Brace
-Hotchkis Subframe Connectors
-Baer Eradispeed Disc Brake Rotors
-315's Nitto Drag Radials in back Brand New
-Fikse FM10s-17x10 in front 17x11 in rear
Steven@latemodelracecraft.com
713.466.9900
Asking $22,500
