FTP 98mm lid + gm 85mm maf + 92mm tb
Old 01-27-2012, 09:35 PM
jdiddyws6's Avatar
Default FTP 98mm lid + gm 85mm maf + 92mm tb
What coupler will connect the maf to the tb??? It is on an ls3 intake, and It appears I need a 4 inch and 3 and 5/8th's ID and at least 5 inches in length. What is being used? I'd rather not pay $100 for a coupler to use with a $170 lid.
Old 01-27-2012, 09:56 PM
trans_am7935's Avatar
i used a SLP smooth bellow i picked up for $40, i have the exact same setup
Old 01-27-2012, 10:00 PM
1999BlueTA's Avatar
I used a 4x3.5 hump gose on my old 85mm setup should be cheap to boot, I think I paid like $15 for it!!!
Old 01-28-2012, 11:55 AM
newchevyman's Avatar
Will this setup work with an LS6 intake? I assume the LS6 opening would have to be ported, right?
Old 01-28-2012, 02:11 PM
1999BlueTA's Avatar
^^^yup I just sold my old setup ported/modified 88mm ls6 intake, ported PP 85mm tb and 85mm maf, upgradind to fast, 102mm tb, 100mm maf and ftp 104 lid!!!
Old 01-29-2012, 01:43 AM
Mazzenger's Avatar
I would go and track down a piece of neoprene tubing from some place that sells turbo accessories (a speed shop or truck shop). Probably cost you $10 or less. I would take the maf with you to make sure it fits. I have only seen blue tubes around here, but you can spray paint them.
Old 01-30-2012, 07:36 AM
usafws6's Avatar
Measure the od of the maf and tb and look up silicon hoses on google. 20 bucks or so. Who would pay 100 for a coupler?
Quick Reply: FTP 98mm lid + gm 85mm maf + 92mm tb
