FTP 98mm lid + gm 85mm maf + 92mm tb
What coupler will connect the maf to the tb??? It is on an ls3 intake, and It appears I need a 4 inch and 3 and 5/8th's ID and at least 5 inches in length. What is being used? I'd rather not pay $100 for a coupler to use with a $170 lid.
I would go and track down a piece of neoprene tubing from some place that sells turbo accessories (a speed shop or truck shop). Probably cost you $10 or less. I would take the maf with you to make sure it fits. I have only seen blue tubes around here, but you can spray paint them.
