ported 5.3 or LS3 heads on a stock LS2 shortblock?
Old 01-31-2012, 06:21 PM
gnx7's Avatar
Default ported 5.3 or LS3 heads on a stock LS2 shortblock?
Trying to decide what to run on a stock 2006 LS2 GTO shortblock that I want to put a set of heads on.
1st set is some hand ported 5.3's with larger s/s valves and dual springs that flow a little more than 300cfm. They made 440rwhp/405rwtq with a 232/234 cam/LS6 intake on an M6 camaro. Approx 59cc
2nd set is from TSP ported LS3 heads with lightweight s/s valves and dual springs. 70cc and flow approx 350cfm
Is it a no brainer to use the LS3 heads and LS3 intake over the 5.3 heads/LS6 intake? The compression will be probably 1 point higher with the 5.3's.
Should I mill the LS3 heads to increase compression? What would compression be with them at 70cc?
Old 01-31-2012, 09:52 PM
gnx7's Avatar
ha ha.... I did a search for a while and found my own thread on this (which is the same) from June 2011!
https://ls1tech.com/forums/generatio...ls3-heads.html
So fast forward 7 months..... Should I stick with the LS3 heads?
Old 01-31-2012, 09:57 PM
Tainted's Avatar
Yes ls3 heads mill off .030 to gain back some compression.
Old 01-31-2012, 10:58 PM
1badeagle's Avatar
ls3 for sure
Old 01-31-2012, 11:20 PM
socal's Avatar
5.3's ported, we did ls3s and it just dosn't pull off the line. the 5.3 will make more torq and get you moving. If you were going w more cubes like a 402, i would say the ls3's.
Old 02-01-2012, 09:58 AM
redtan's Avatar
On a normal street car with ~3500 or more curb weight I would say the 5.3s with higher compression for increased torque down low.
But seeing how this is going to go (correct me if I'm wrong) in a sub 3000 curb weight car I say go for the higher flowing LS3s as you probably won't miss much of the low end torque on such a light car.
Old 02-01-2012, 10:02 AM
Tainted's Avatar
mill the ls3 heads to gain back some compression. hell you can always flycut your pistons to run larger cam/more compression!
Old 02-01-2012, 11:51 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Be careful with the 5.3's on an LS2....your compression gets up there quick with them, especially after any milling! With the right cam selection, I think the LS3's would work very well on the LS2 short-block for you.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-01-2012, 05:31 PM
amwellls1's Avatar
I would say 5.3's exept for the fact that 59 cc is going to put the compression ratio up there
Quick Reply: ported 5.3 or LS3 heads on a stock LS2 shortblock?
