E85 4.8 mpt70 - audible ping, no KR - why?
I finally made the switch to E85 and I am working on my fueling. I also switched to a boost reference FPR which is requiring me to do some VE work.
Anyways, I am hearing some pinging under heavy acceleration... WHY??
Here is my setup:
'08 LY2 4.8 9.2CR
LS6 springs
TR6 plugs - gaped at .035" (which I need to lower)
mpt70 turbo @13psi
timing is 16*
IATs 80-100*
Commanded fuel 7.35(e85)AFR
Actual WBO2 reading - 6.95(e85)AFR - a little rich, still dialing that in.
ECT 195*
I know i need to lower the plug gap, i am also getting some high RPM misfire.
Ideas?
Thanks,
David
Here is my setup:
'08 LY2 4.8 9.2CR
LS6 springs
mpt70 turbo @13psi
timing is 16*
IATs 80-100*
ECT 195*
Ideas?
Thanks,
David
Wow! 6's on E85. I am using -9 NGK's. You should be an 8 or 9 on E85. I also agree with a lower thermostat. Mine fires right up with no fouling on a 9 right now. If it does start to foul I will switch to an-8 but nothing hotter than that.
Thanks for the info. I agree that I should not even be close to seeing/hearing KR at these levels. I sure do see a lot of mixed results on who is running what plug. So, switching to a colder plug (B8EFS) - would that fix my issue? I'm going to do it anyways - just curious...?
Here is a pic of my #1 plug (TR6)
Thanks,
David
Thanks,
David
My FPR is set to a static 58psi with a 1:1 rise in fuel. What are you commanding for your WOT E85 fueling?
Thanks!
David
I find it REALLY hard to believe that you're knocking on E85 at ALL. You sure you're not mistaking it for valve float and plug blow out? LS6 springs aren't going to hold up to much boost especially if you have high back pressure or are revving high. Get some colder plugs (I'd go BR7EF) gapped at .024" in there for good measure and go from there.
Plug strap heat wise looks good as does the porcelain from what I can see, but the bottom ring on the porcelain matters more than the top and I can't see that in that picture. It's also hard to tell where the actual timing mark is.
I'd go to a BR7EF and wouldn't worry about a colder plug till you upped the boost a good bit.
BTW what's the TSL on?
Your timing and boost level is fine, so are the plugs and valve springs. However going to 7 heat range would be a good idea. Might be possible that big gap is causing some blow out and making some odd sounds in the process. I was fine on the ls6 springs up to around 15psi. Past that your going to make good gains swapping to better spring.
Swap in some 7's at .026 and do a compression check as you go around.
Best of luck man.
Also to back it up, this is my graph/ old setup. TR6's, MP70/P .81 a.r, 15psi and 16 degree timing, LS6 springs on a 4.8L.
Best of luck man.
So I pulled the plugs, replaced them with BR7EF@.026. All of the plugs looked ok, just like the pic above. Compression is solid across all 8. Still on the LS6 yellow springs. Maybe I am mistaking it for valve float? This isnt your old school chevy 350 "jingling" ping... its just a mild ticking, mild enough that i probably couldn't record it. You hear it under full load at 5000+ rpm. If you are detonating it bad enough, wouldn't you surely see it as KR in the logs?
I'll toss in some patriot gold springs that I've had for a while - hopefully Sunday, that will certainly fix the valve float questions
I've attached a log if someone wants to take a look. (EFILive)
Thanks ALL!
-David
Thanks ALL!
-David
What are you gapping the plugs to? My guess is probably blow out. I have run stock heat range plugs in many E85 turbo cars and never had an issue (stock for Subaru). But when running all the fuel, you can sometimes get spark blow out if you are gapped too wide. We usually run around .024-26 gap.
