check engine light on
got my damn light on again...swung by autozone and see what the deal is and they told me it has codes saying both banks are running lean...said it could be the mass air flow sensor...i recently put on a k&n cai and ever since has acted funny... any suggestions
Do not over oil a k&n or you will clog the MAF. Buy an $8 can of MAF cleaner and soak it down on the bench, after it drys out completely bolt the MAF back in and try it
i'vew got a sable sitting out in the bay. p0174. that's bank2 lean. the lower intake's leaking like a pig.
I was getting lean codes and after trying everything, including replacing the MAF and the O2 sensors, it ended up being a crack in my L76 intake manifold. The shop felt like it was a defect in the manifold from the factory that finally cracked with the heat cycles.
