Pontiac GTO 2004-2006 The Modern Goat
check engine light on
Old 02-03-2012, 08:26 AM
BSGTOLS2's Avatar
Default check engine light on
got my damn light on again...swung by autozone and see what the deal is and they told me it has codes saying both banks are running lean...said it could be the mass air flow sensor...i recently put on a k&n cai and ever since has acted funny... any suggestions
Old 02-03-2012, 08:59 AM
mark21742's Avatar
Do not over oil a k&n or you will clog the MAF. Buy an $8 can of MAF cleaner and soak it down on the bench, after it drys out completely bolt the MAF back in and try it
Old 02-03-2012, 09:03 AM
1ltcap's Avatar
what he said. i'cve seen that a LOT
Old 02-03-2012, 09:16 AM
BSGTOLS2's Avatar
ok ima try that
Old 02-03-2012, 09:18 AM
BSGTOLS2's Avatar
and if that doenst work should i replace the maf...and if i do what kind should i buy
Old 02-03-2012, 02:59 PM
gconnoyer's Avatar
Check the maf
Also, check the bolts on the intake manifold. Someone I know had all of theirs come lose, their cars ET was waaay off and he had a lean on both bank code.
Check the fuel rails as well.
Old 02-03-2012, 04:48 PM
scphilli's Avatar
+1 on cleaning your MAF. In addition, check for air leaks on the engine side of the MAF. If air is getting in that is not being logged by the MAF you will get lean bank codes
Old 02-03-2012, 05:00 PM
BSGTOLS2's Avatar
copy all, thanks fellas, bad news is i am off shoreand cant fix her till i get home driving me nuts
Old 02-03-2012, 05:04 PM
1ltcap's Avatar
i'vew got a sable sitting out in the bay. p0174. that's bank2 lean. the lower intake's leaking like a pig.
Old 02-03-2012, 05:13 PM
mark21742's Avatar
If you need a MAF get a stock replacement
Old 02-03-2012, 05:32 PM
Robofuzz's Avatar
I was getting lean codes and after trying everything, including replacing the MAF and the O2 sensors, it ended up being a crack in my L76 intake manifold. The shop felt like it was a defect in the manifold from the factory that finally cracked with the heat cycles.
Old 02-03-2012, 09:26 PM
BSGTOLS2's Avatar
well if it is the intake that will be every excuse for me to get a fast intake hahaha
Quick Reply: check engine light on
