Engine Bay Cleanup
The following users liked this post:
Transam53 (02-22-2024)
truck bed liner
if you ever pull then engine clean the bay up then spray down some rustoleum truck bed liner.did this to my 95 and it looks really good and is real tough
LS1Tech Sponsor
I'm always a fan of doing some custom Fuel Rail Covers. Take some from a C5, fill in the CORVETTE lettering, and have them paint matched to the car, add some CAMARO or TRANS AM badging to them where the CORVETTE was and it looks great IMO.
Wire mod is also nice, polish up the brake lines
Just make it spotless!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
If you're looking for a PCM, power steering, brake fluid cover, etc. We've gotcha covered http://yofab.com
I did the "wire mod"
Also used simple green to get rid of all the grease/grime. (after using it make sure you wash it off really good because it starts to eat away on the paint)
Little bit of engine dress up
Re-painted my LID & the back of my headlights while doing the whistler mod
LS6 intake is painted silver aswell
maybe power wash if you cover everything besides the block but I wouldnt use something with high pressure, possibility to rip a wire loose from something probably not likely but i wouldnt risk it, its best to just use a sponge or rag and soapy solution and rinse with hose and dry with a towel.
