cracked block suggestions
Old 02-06-2012, 11:00 PM
jay7199's Avatar
Default cracked block suggestions
this is my buddys block, its a 99 or a 2000 ls1, he sent it too the machine shop for a vats cleaning and cam bearings and after the cleaning found this..
What do?
Old 02-06-2012, 11:03 PM
sjsingle1's Avatar
surface crack? or much deeper? if its surface i would say no problem
Old 02-06-2012, 11:10 PM
jay7199's Avatar
not 100% sure but it looks like a stress crack from not cleaning the headbolt holes before installing new heads (previous owner)
Old 02-06-2012, 11:19 PM
Jonsgreasemonkey's Avatar
It's pretty deep. the two sides of the crack are different heights, 3/4 of a millimeter. I can see quite a ways into it, but light doesn't pass into the bolt hole or vice-versa. I'm trying to take some better pictures.
Thanks Jay.
Old 02-06-2012, 11:23 PM
Mako77's Avatar
looks like scrap to me... Might be able to so that metal stitch technique.
Old 02-06-2012, 11:29 PM
jay7199's Avatar
my thought was weld it and helicoil it..
Old 02-06-2012, 11:30 PM
deepest spot I found was 6.3MM
Old 02-06-2012, 11:39 PM
I should point out that the machine shop either missed it, or failed to notify me of the crack and put my brand new clevite cam bearings in anyway.
Old 02-06-2012, 11:42 PM
technicalninja's Avatar
That looks like a head bolt hole. It's toast. I'd chuck it.
There was someone looking for a bad aluminum block in the classifieds to make a table out of...
You might look him up.
That's only good for furniture now!
I'd find another machine shop unless they replace the cam bearings.
I might find another machine shop anyways...
Old 02-06-2012, 11:47 PM
It is in the head bolt hole.
Old 02-06-2012, 11:50 PM
JWStevens's Avatar
It can be fixed but if you pay someone to do it the cost may not be worth it? We always use Fowler or Brodix to fix our crap.
Old 02-06-2012, 11:59 PM
I think I'm just going to use the 5.3 I have laying around. The ls1 was gonna go into a daily driver. I just need a running car since the cam in my 3.4 bit the dust. Any motor is going to be better than the 94hp that 3.4 put out.
Old 02-07-2012, 12:11 AM
bww3588's Avatar
Iron block it. I'd get some LT1 front springs to deal with the additional weight tho or it's going to be wandering all over the place.
JWStevens's Avatar
If you end up using it try a stud on that hole. It might help?
Old 02-07-2012, 07:09 PM
5.3 parts ordered. Now there room for some power adder later.
Quick Reply: cracked block suggestions
