Maf, open loop tuning, which tables, 95 OBD1 using tunercat.
This is for a '95 OBD1 pcm using tunercat. After reading numerous threads I am more confused than ever. I am trying to tune my car using the maf in open loop only using my wideband sensor. I thought I would use the "maf calibration tables" for idle and partial throttle driving. Then use the "% change to afr vs cool. temp at wot" with the "% change to afr vs rpm at wot" to tune wot. I heard these are the power enrichment tables.
Well after reading to much threads I have heard that in maf open loop tuning you need to use the "afr vs cool. temp vs map" to tune wot because supposedly maf open loop tuning won't use the power enrichment tables. Not sure if any of this is true but can anyone help me.
Which tables are effective at doing what if anything in Maf Open Loop Tuning?
1. maf calibration tables
2. % change to afr vs cool. temp at wot" with the" % change to afr vs rpm at wot (power enrichment tables)
3. afr vs cool. temp vs map table
Idle should use -
Partial throttle (cruising) should use-
Wot should use -
Idle should use -
Wot should use -
