Vacuum
Old 02-09-2012, 02:10 PM
99WhiteKnight's Avatar
Default Vacuum
I just recently had a D1SC installed and I have a question about vacuum. When I first got the car back my boost/vac gauge would read about 3-5 inches of vacuum driving under normal conditions. Now I see anywhere from 10-18 inches of vacuum. Im new to boost and I wanted to get some opinions from you guys to see if I have a problem or not.
Thanks
Old 02-14-2012, 01:58 PM
Ok I got the car up in the air and checked and tightened all the couplers from the head unit to the throttle body. Then cranked her up, and I am still seeing 10-18 inches of vacuum. Can anyone suggest anything else to check or look for?
Thanks
Old 02-14-2012, 03:13 PM
2005vetteTT's Avatar
you're fine. the amount of vacuum is different per amount of throttle. my car idles at 15-18 inches
Old 02-16-2012, 01:21 PM
Ok great, thank you. I feel much better now.
Quick Reply: Vacuum
