valve spring/rocker arm question!
Old 02-17-2012, 09:00 PM
speeddemon89's Avatar
Question valve spring/rocker arm question!
i have a 416ci ls3 turbocharged. i have a 235/231-.621/.617-115 cam. im trying to install a 243/254-.638/.638-116. i called thunderracing and they said my patriot gold valve springs were no good for this cam which is right but he also said never to use them because they are a low quality valvespring and pretty much suck and that i proberly have floating valves with them.....any thought anybody? and he said my harland sharp alum roller tip rockers are garbage and i i am getn floating valves from them too, and i should put my stock rockers back on weither i use the cam in there now or with the new one i want.... just wanna hear thoughts from people, what springs or rockers i should go with and is this guy right or wrong... thanks
Old 02-18-2012, 07:39 PM
S10xGN's Avatar
Shane knows his chit, besides ******* out your parts I'm sure he recommended the correct springs. Nothing reasonably priced can beat the stock rockers with a trunnion upgrade kit...
Old 02-20-2012, 02:11 PM
george g's Avatar
I just ran into the same problem with patriot springs floating out on me at 5,800 and causing me some hp.
Old 02-22-2012, 01:36 PM
TurboBuick6's Avatar
Stock rockers with the trunion upgrade and a PAC-1207X.
Quick Reply: valve spring/rocker arm question!
