Best cam For this ls2
hi guys , i have camaro 01 i want setup best cam for this engine :
block Ls2 Aluminum stroker 408
wiesco piston -3 flat top
Eagle con rod 6.125
Eagle crankshaft
Heads ls3 PRC cnc
slp pulley
intake Fast + TB 102mm
dubl chain slp
oil pump maling
injecter 42
i need help for selection cam ???
Eagle con rod 6.125
Eagle crankshaft
Heads ls3 PRC cnc
slp pulley
dubl chain slp
oil pump maling
injecter 42
Spend the $50.oo and have Patrick G. speck you one.
LS1 Tech Administrator
Do those heads have the hollow stem intake valves or the solid stainless versions? This makes a big difference on lobe selection as you can't run really fast ramps with heavy valves.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Entirely too big for a 6.0L with ported LS3 heads. You're 13-15 degrees too big on both sides of duration.
__________________
Most likely your going to need some bigger injectors as well. My 6.0L, CNC LS3 heads, 219 @ .050 cam had my 41lb/hr injectors at 80% DC. Your larger engine displacement and larger cam thats needed to match will probably go beyond what the 42lbers can handle. Just keep it in mind.
