Pontiac Firebird 1967-2002 - Dropping the fuel tank, 96 LT1 Trans Am
LastKnight
02-19-2012, 01:41 PM
Before I drop the fuel tank to replace the pump, I wanted to ask--How much space is there between the interior steel trunk panel and the surface of the fuel tank? I was going to use a reinforced Dremel cutting disk to make the fuel tank access panel.
Any recommendations? I have true duals that clear the tank, so dropping it shouldn't be too hard if I have to. Thanks.
mrrman
02-19-2012, 01:45 PM
I did the access panel cutout in the 87 TA and there was an easy 1/4" before any contact was noticed anywhere. Any one else can make a comment on this. I have no regrets doing this.
Paul Bell
02-19-2012, 08:34 PM
Lotsa good info & links here:
http://www.ls1tech.com/forums/fueling-injection/1484418-trap-door-fuel-pump-access-where-cut.html
y2k_ta
02-21-2012, 03:02 AM
If it were my car, I'd drop the tank. If the cut-off wheel would happen to grab and slice into the tank you'll be dropping the tank and buying a new one.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
