BOV Placement...Who's Right?
I’ve searched and read extensively and it seems there are 2 divided camps on this issue; before the intercooler and after it. I understand the logic behind both arguments. Before the intercooler will vent hot air before it passes through the intercooler, keeping the intercooler cooler and therefore reducing the incoming air temperature. I also understand closer to the throttle body after the intercooler as not to send a shockwave of air through the system when the throttle blade closes. My question is, for the average 500-600 horsepower turbo car, which is better? Does is not really matter at that power level? Is there anyone out there who’s tried their BOV in both positions and saw a difference with some data to back up a better placement? Any answers would be greatly appreciated.
Your personal theory is just a theory.
The speed at which pressure equalizes in a system is damn fast. Its not like you will have 15psi at one end of a 3" diameter pipe and 5psi at the other end for an extended amount of time. The pressure will equalize in a fraction of a fraction of a second.
There are some formulas here if you want to read up on the subject.
http://www.air-dispersion.com/msource.html The first one is what you want to figure out.
You don't hear about guys with rear mounts blowing up their turbos with a BOV at the front of the car for this reason. The pressure differential between the outlet of the turbo and the throttle plate is negligible. You could probably barely tell the difference if you were to put a boost gauge on both the start and finish of the charge pipe and compare them simultaneously.
To the superchager comment:
How are you heat soaking if you aren't actually compressing any air with the valve open? The compression of the air is what generates heat, not the fact that it flows through a supercharger. Charles gas law.
7 Second Club
I can see how if you didn't have any real experience and instead just relied on general physics laws you would think that. In real life you can watch the intake air temp jump pretty heavily with the BOV after the intercooler when free reving the motor because after all the supercharger is still compressing air and pushing it through the pipes/intercooler, etc even though it's not "building boost" into the motor since the BOV is open. This is pretty simple and easily verified by anybody who has tried both with a sensor right after the intercooler.
It's quite staggering that nobody has mentioned the ONLY important aspect for BOV placement.
Which is before the MAF assuming you are still using one. ( ie between the compressor and MAF, but not too close to the MAF )
Yes, but placement before or after an intercooler makes absolutely no difference whatsoever so is completely unimportant..
On a blower, defanitly before the intercooler. Ive felt the air from a blower just at idle and it's still hot air.
On a turbo, closest to the tb as possible. Thts where it will build pressure first. but there might b a small gain in anti-heat soaking by having it before the ic. But only when making back to back runs.
The supercharger is definitely NOT compressing air if the bypass valve is open. Thats like saying the air coming off a desk fan is significantly warmer.
If you are worried about heat soaking the intercooler from bypass air, then you have a crappy intercooler. At speed and when not making boost, the intercooler should return to normal operating temperature in a couple seconds.
The simple fact is, the BOV should go wherever it is best packaged. You can put it literally wherever you want, wherever it looks nice, or wherever it is easiest to work on. On a MAF system, however, you should put the BOV before the MAF so you don't get false readings.
7 Second Club
No you apparently don't otherwise you wouldn't say the crap you are saying. Put your hand in front of a blower and rev it, that's hot air and it can be quite a bit hotter than ambient because of how the air is compressed by the compressor wheel just to move it whether it's free flowing or not.
Absolutely correct, when it's revved up you can certainly feel the heat and if you rev it hard it can get really hot.
Air is NOT being compressed by the compressor if it is not building boost. The pressure differential is tiny when the blower isn't hooked up or when it is bypassed. A boost gauge would read 1atm with the bypass open, so NOTHING IS BEING COMPRESSED. What you are feeling is the heat from the worked blower transferring to the air flowing through it.
In any case, BTUs you are feeling are incredibly insignificant compared to the BTUs generated and transferred to the charge air when you are actually making boost. This small amount of heat is EASILY transferred to the atmosphere by any intercooler, even a small one. The intercooler probably gets more heat input from the hot radiator radiating heat behind it than the bypass air from a hot supercharger
7 Second Club
Something like this is so stupid simple that anybody can test and see the results yet you keep arguing like you are correct. The facts remain, revving a blower up without "building boost" still produces quite a bit of heat that will drive up IATs even through a good intercooler with no airflow going through the front of it.
I am done arguing with you over the internet, anybody can feel it for themselves or use a scan tool it's very easy.
TT-TECH Veteran
