5.3 ls swap to 84 suburban c10 custom deluxe
Old 02-21-2012, 04:33 AM
84 subratban's Avatar
Default 5.3 ls swap to 84 suburban c10 custom deluxe
hi guys
i need some information i need know to what year 5.3ls engine and transmission to make it work on my 84 chevy suburban 2wd runs with carb i know i have to swap some parts to make it run right like fuel pump engine mount so i need to know about driveshaft old one fits on a 4l60e ?? im on a tight budget.. i would like to elimate it OS sensor i want throttle cable not by wire ..... let me know i need some help thanks ...............
Old 02-21-2012, 06:30 AM
LS1Tech Sponsor
psiconversion's Avatar
Are you going to run a carb or EFI?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 02-21-2012, 07:13 PM
EFI ........... i would like to programmed the ecu to add or reduce the MPG .........
Quick Reply: 5.3 ls swap to 84 suburban c10 custom deluxe
