LS2 stroker single turbo setup...
Old 02-21-2012, 07:54 PM
Restricted User
zx10rcobra's Avatar
Default LS2 stroker single turbo setup...
I've had my motor at the machine shop, getting ready for some diamond pistons, compstar 6.125 rods, CNC'd SD LS3 heads, etc... for a single turbo build. I'm unsure as to how big i'm going to go with the turbo, but i want to hit 1000whp for sure. Rather than nitrate my stock crank, i went ahead and ordered a new 4.000 stroker crank from ohio crankshaft for the build. After talking to some guys with experience with these LS motors, I am worried about the runnign the stroker crank with a turbo setup. I was told that the heat generated will causethe bearings to fail in time... that has actually happened to a local guy with a similar setup as well... but I had written it off as bad luck. Do you guys have any input on the subject? Will i run into problems with a stroker on a turbo setup? I built this car to run as well, so i plan on laying into it often. thanks
Quick Reply: LS2 stroker single turbo setup...
