exterior plastics fading
i have a 2002 z28 camaro that sat for two year before i got it, it sat in the direct sun alot which lead to some of the exterior plastics to fade. does anyone know how i can restore them or replace them. it's starting to become very noticeable.
Back to Black will probably do the trick, try that first. Otherwise, use a heat gun (careful not to touch the plastic) and it will make it black again, then hit it with the Back to Black and you should be good.
I had some really faded trim on my old chevy truck, used a blow torch and it looked really good, then I used some off-the-shelf meguiars aerosol tire dressing (don't remember the name) and the trim looked very black after knocking down the shine from the tire dressing. Don't use a blow torch on yours though lol I toasted some of the plastic doing it
It the bottom of the door windows and the sail panel rubber on the back side of the door window. I paint correction on the paint and looks great. The rubber under the door window and the rubber part on the sail panel has swirl marks. How do i detail it?
http://www.adamspolishes.com/p-512-a...-dressing.aspx
They also have an aerosol version:
http://www.adamspolishes.com/p-517-a...-dressing.aspx
Neither of these will restore the plastic back to original, but they will make it look better. Well, depending on how faded the plastic is...hard to tell without a picture.
My old camaro had that kind of issue with the weatherstripping, I think I used armor all but you have to knock it down cause it doesn't really soak in. Don't take my word for that though. I never touched the sail panel. It's plastic so the armor all won't do anything.
I'd ask Jeff or Junkman these questions.
